Does anyone have the Gaede auction results?
rusty
07-20-2003 19:23:32
Did not go but would like to know how things sold out in Colorado?
JDVan
07-21-2003 20:06:29
 Re: Does anyone have the Gaede auction results? in reply to rusty, 07-20-2003 19:23:32
Here is some info I picked up off of another board:
1964 JD 8020, nice original,ran great-$20000 2-840's,believe one went for $2500 and other under $1500. Both needed work 830I-repainted g/y, driven to auction from storage, nice $7500 820 black dash, did not run-$2100 1959 JD 630LP standard,nice!1 of 16-$70000 630 all fuel, 1 of 181, restored with mounted cotton picker, entire rig super nice, restored, field ready $36000 435,average, ran good-$7800 1934 open fanshaft A,average restoration,cutoffs-sn#411255-$5800
430 HiCrop,stuck, 1 of 183,needed work-$10500
JD Holt Forklift,good, 1 of 36-$30000
420S LP, 1 of 23, repainted,runs-$23500
420 HiCrop, 1 of 246-$7400
402C w/blade,3 pt, super nice original, low hours, nice-$13500 330U Industrial sn#330780,replacement serial tag but verified by research,needed restoration, 1 of 17-$14000 33S sn#330807, original, 1 of 844-$19500 320U sn#322550, industrial, 1 of 716,rough-$6000 70LP standard, sn#7030575,good,1 of 336-$8100 60 all fuel hiclearance sn#6013614,stuck, 1 of 135 ROUGH!-$5000 40C sn#62089, inside mount blade, yellow over original green,runs-$2750 40C sn#63489 w/Lindeman blade, ok $4000 A Hicrop sn#670744 w/single front,stuck, 1of 246-$16000 A sn#447716, not stuck, 1937 year, average-$2000 1937 ANH, sn#465114, 12 spline 40" rs rears,$14000 1947 AO sn#268219, original, lights,$6700 1936 AR sn#250276,restored, full steel-$4700 1946 AWH sn#578615, runs good, $4700 1938 AWH sn#475793, 1of 27-$35000 B sn#1928, FOUR BOLT B, rs rears, $6400 1941 B HiCrop CONVERSION, SUPER TALL, 12'???sn#115293,wide front, JR pointed out it was a Ford N series front axle adapted over, $4100 1946 B HiCrop CONVERSION, SUPER TALL, 12'??,sn#189105, single front, different conversion, rougher than the other, $4100. These were sold for "choice", winner took both for $4100 each BR sn#327440, full steel, okay, free engine-$7700 1938 BWH-40, sn#51910, 40" rs rears, stuck, 1 of 14-$81000 1938 BWH sn#57349, 40" rs rears, stuck, 1 of 14-$61000 1925 Spoker D, sn#32491, w/PTO,had 1929 flat spoke front steel,nice tractor, $17000 40" rs rears for A-$750 pair BWH repro fenders, rare-$1100 BR front steel $2000 A front steel $2000+ A skeleton rear steel, drawin hubs-$1000 1928 DX sn#X67507, experimental exhibit A,full steel, restored, 1 of 97-$29000 1930 DB sn#B107045, experimental exhibit B, full steel, not restored, stuck,1 of 50-$19000 1938 G, Experimental, sn#1045, SUPER RARE, no "JOHN DEERE" cast into radiator, believed to be the very first tall radiator G and the one that the testing was done on, good, $32000 1938 G sn#1684, incomplete, chassis, basically frame/trans/block/pedestal-$1600 LoRadiator G kit-radiator,pipes,aircleaner,tank,hood-$5500
1934 GPWT over the top steering,rare rear steel w/over tire bands,rs fronts,NO serial tag, $17000 1941 HNH sn#36583, 1 of 37,stuck,rusty,complete-$39000 1941 JD HWH, sn#36526, had the "wide front base", 1 of 125-$17000 LI SN#50021 w/sickle mower, disassembled, parts missing,advertised as the first LI but found to be the 21st-$1950 1951 R, ran-$2500 JD WA17 Wagner sn#000105GC 4WD, 1 of 28, ran great, looked good-$22500
Other nonJD items sold well, an Oliver-Hart Parr Industrial 18, first one built, restored, $16250 Twin City 20-35, full steel-$3900 Massey 98 LP FWD-$4100 1930 Cat 10 HiCrop sn#PT4039, one owner, nice -$14750 1932 Cat 15 Hicrop sn#1D60 (??), very average-$12000 Harris Power Horse-$9200
