1939H gear jumper
ron brewer
07-20-2003 18:42:00
My 1939 JD H pops out of 1st and 3rd gear when under even light load. I've tried adjusting the shifters using the set screw on the left side just behind the flywheel, but haven't had much luck, so far.
Does anyone have any ideas where I should be starting to solve this problem? Right now I using trial and error and just hitting errors.
Thanks in advance.
Clooney
07-21-2003 03:19:39
 Re: 1939H gear jumper in reply to ron brewer, 07-20-2003 18:42:00
Ron, that could almost anything in the trans or shift parts. The usual cause is worn shift rail detents, worn shift rail notches, worn trans bearings, or worn shaft/gear splines. ~You probably should pull the shifter cover & rear cover & reach in with a bar & try to pry the shafts & gears around to see how much movement you have. You might also be able to see the gear line up when in each gear so you can verify that the gear sets are fully meshed when in each gear.
