JD Model D crankshaft spec
Jon
07-20-2003 17:52:22
I am rebuilding an unstyled "D" s/n 143458.
1. The connecting rod 'throws' on the crankshaft are out-of-round. Does anyone know how much out- of-round is acceptable on these engines?
2. If the throws need to be ground, I will have to remove the counter-weight mounted on the crankshaft so that the machine shop can grind it. I assume that I can ground or mill off the weld that locks the nuts on the studs that support the counter-weight.
Paul from MI
07-20-2003 18:28:52
 Re: JD Model D crankshaft spec in reply to Jon, 07-20-2003 17:52:22
Jon,
Kind of depends on your intended use, your own tolerance for "not quite perfection", and how much out of rounbd the journals are. I have a 1941 A thats got the original bearings. When I bought it 27 years ago I did a quick ring and vale job on it. The crank was out of round about .0025" at that time. Since money was tight, I just adjusted the rod bearing shims as good as I could get them and ran it. It's been 26 years, still running with no unusual noises, good oil pressure, not burning any oil, etc. This tractor doesn't see a lot of hard use but it's one that is used every few days for something or other.
Yeah, I wish the crank was in better shape, but it doesn't seem to hurt much within reason.
Paul
jon
07-20-2003 18:54:59
 Re: Re: JD Model D crankshaft spec in reply to Paul from MI, 07-20-2003 18:28:52
Paul,
I'm picking up a new 3-4" micrometer tomorrow but I think they are out-of-round by 0.010" to 0.015 inches which is excessive - I believe. I've been told that excess clearance allows the lubricating oil film to break down and allows metal to metal contact. That's why I'd like to know what the industry accepts as maximum out-of-round for 3.500 inch diameter crank throws.
Regards,
Jon
Paul from MI
07-21-2003 18:36:40
 Re: Re: Re: JD Model D crankshaft spec in reply to jon, 07-20-2003 18:54:59
Jon,
I'd be leary of anything more than .003 to .004". The original rod bearing specs allowed about .003" tolerance on the clearance, so I kind of figured I could allow that amount out-of -round if I kept the bearing clearance on the tight side. So far it's worked for me. If you are in the .010" to .015" range you definitely need to grind the crank. Good luck,
Paul
