4020 load shaft
Pat 77
07-20-2003 16:56:21
After pulling the load shaft and replacing the seals, I cannot get the shaft past centerline where the sensor arm is located. The load/draft handle will not move. It is in the "D" position. How do I get the inside part to move out of the way so I can get the shaft to go all the way through? The S/N is 213,000.
ET
07-21-2003 13:02:34
 Re: 4020 load shaft in reply to Pat 77, 07-20-2003 16:56:21
Did you try moving the lever that raises and lowers the hitch? I somtimes roll the loadshaft and push at the same time, the notch will help to walk it by the arm in there. Some of the side console tractors have a set screw in the front of the load shaft casting under the tractor that needs to be backed out to get the shaft in. Its a stop so the load shaft won't move the control linkage backwards.
Pat 77
07-21-2003 13:20:25
 Re: Re: 4020 load shaft in reply to ET, 07-21-2003 13:02:34
Thanks ET,
I moved the handle that controls the rockshaft all the way forward, which lets the lower links down. The load control linkage is stuck, so I tried to rotate the crank where it enters the valve case, but it won't turn. I tried rolling and pushing the load shaft, it just got past the bracket but thats when it got too hard to push by hand. I twisted on the very end (half moon end) with water pliers while I pushed, I guess 50 pounds of force. I'm afraid to get rough with it. There is a pretty good angle on the shaft at that point.
I'll look for the stop you mentioned, but the arm appears to be too far forward (3/4") to get the shaft past, not backward.
ET
07-22-2003 06:43:01
 Re: Re: Re: 4020 load shaft in reply to Pat 77, 07-21-2003 13:20:25
Not all tractors had the negative signal stop. Rotating whith the pliers is what I do also. I get a little braver and rap the end with a hammer, but I don't pound. If its going to go by it only takes three or four raps to get it.
JimKS
07-20-2003 19:44:19
I just replaced one of those the other day... If D is the down position, then that's where the depth control should be... I have to think that you have some stuck linkage or somehting... my only suggestion is that maybe you could stick a smaller diameter bar in the other side and mabye pull the linkage to line it up with the load control shaft. If the depth control lever is down, then the arm should be in the right position already unless there's a linkage problem.
Pat 77
07-21-2003 05:36:46
 Re: Re: 4020 load shaft in reply to JimKS, 07-20-2003 19:44:19
Thanks Jim,
The linkage is stuck in the "D" position and won't move. I took the linkage off and tried to turn with a wrench but no luck. I hope this can all be accessed from the top without a tractor split.
