70 JD crankchaft quistion
Dale
07-20-2003 09:58:17
I have a lose flywheel on my 70lp Standard. I need to now how to check and see if my crankchaft if also worn down. What should the crank mik at. Thanks for any info.
Lee
07-21-2003 01:37:55
 Re: 70 JD crankchaft quistion in reply to Dale, 07-20-2003 09:58:17
I would think the crank should mic within .010 of the main bearing spec - I don't have anything to do with numbered series so I can't claim to really know. But they can run loose for a while without needing a new flywheel or crank or even a taperlock. Perhaps all that is really needed is to swap out the bolts and nuts for grade 8 flavor and add some real twistem to it?
Bob
07-20-2003 21:04:57
if your flywheel is worn your crank is worn. JD's solution is a new flyhweel and crank. A taperlock flywheel will fix the problem for a lot less money
