A manifold
Scott in SC
07-20-2003 04:51:22
The manifold on my All Fuel 52 A has a gasket failing on the exhaust side. Looks like the tractor has had a head job at sometime in the recent past. The manifold bolt heads look good, but don�t budge at all. No portion of the bolts are exposed except for the head, so I doubt PB Blaster will help much. Anyone got any tricks that my help with removal of the manifold while head/manifold are still on the tractor?
Clooney
07-20-2003 09:45:32
 Re: A manifold in reply to Scott in SC, 07-20-2003 04:51:22
Scott, start by applying some penetrant to the bolt heads on top of the manifold. Then use a hammer & drift [or rod] & give the bolt heads a couple of good raps with a big hammer in both the lateral & vertical directions. Then use caution & about as much force as you feel comfortable with & try to loosen those bolts. If they come loose fine,,if they still don't want to come loose DON'T FORCE THEM. You don't want to break a bolt where it enters the cylinder head.
~Remove the ones you can this way & on the ones that won't come loose drill or cut their heads off at the top of the manifold. Then rap the manifold on the side in a few different directions with a block of wood to loosen it on the cut off bolts [add penitrant at the top & maybe a little heat]. You might find the bolts are rusted solid in the manifold holes & not the head threads, if so you will have to heat & beat & work the manifold loose on the bolts.
~Once the manifold is loose on the bolt ruminants, pry it up as far as possible, then stuff old rags or paper towels in the ports below the manifold, then use a Saws-All & cut the bolts off at the bottom of the raised manifold. At that time the manifold will slide out leaving a short stub of bolt sticking out of the manifold. ~You can then use heat, penetrating oil & a pair of Vise Grips to remove the bolts stubs sticking out.
~If you try too hard to get those bolts out without doing the above & manage to break them even with the top of the cylinder head they are much harder to remove..... .
John D
07-20-2003 08:44:41
Scott, the only thing I can think of is to try removing the bolts if they twist off take a heavy screwdriver and put it between the manifold and head and try to drive it in a little, then go to another spot and do the same thing until you go all around the manifold then when you have it up against the fan shaft, you may be able to take a cutting torch and cut the bolts off or maybe a hack saw??? You havn't got anything to loose worst thing youll have to do is take the head off.
John
John T
07-20-2003 07:33:27
Scott, if it really has manifold "bolts" and not studs and nuts as you indicate, I have had some luck extractign them by applying heat where possible to the head around the area where the bolt threads are embedded, and then use a good 6 point socket on the bolt head and hit the wrench end with a hammer to shock the bolt loose. A hammer and shock is much better than a dead torque pull usually. That works on the outer, but the inner bolts you can't get heat to so well. If it has studs and nuts, almost any nut will eventually come off the stud if heated. Try and heat the nut and not the stud as much as possible which would soften it causing it to twist off. The problem is also the bolts are corroded and stuck to the manifiold in addition to beign stuck in the head threads. If worse comes to worse, you may have to cut the bolt heads off and try and lift the manifold, then cut the bolts off near the head and end up welding washers and nuts on the broken bolts to extract them or maybe even have to drill them out grrrrr rrrrr rrrrr r. When installing new studs, I chase the head threads (DO NOT rebore or tap too deep if you replace studs) and use a lot of anti sieze lube on everything and stainless or brash nuts and washers.
Good Luck
John T Nordhoff
Rob
07-20-2003 05:29:52
I have a 1950 A parts tractor that I had taken the manifold off of and all I did was soak it down with PB Blaster for a few days,the nuts were still alittle tight, so I took a torch and put alittle heat to the nuts in one spot only, and they came off pretty easy, as soon as the nuts started to become tight I stopped turning them and put a little more heat to them.I am still a little wet behind the ears on this wrenching stuff so you may want to wait for another comment,I'm sure some of the other guys that do this all the time have other tricks up their sleeves.But my tractor is pretty much stripped so I wasn't really worried if the studs broke or not,but the PB and heat did the trick!! Good Luck Scott
