Hand Staring B
Mark
07-19-2003 16:00:04
I have a 36B I bought at an auction for fun, and I think I am about to start spending money. Last summer I could hand start it ok, but now I have to pull it. I have a lot of things to start checking, gas, plugs, timing, carb, etc. Our '46B has valves to lessen compression for starting, even though it has a electric starter, are they available for the '36 as well? Where?
Dan
07-19-2003 19:44:24
 Re: Hand Staring B in reply to Mark, 07-19-2003 16:00:04
I believe Petcocks could be put on all Bs but some didn't have them to start with. I would think the 36 would have a Mag. If it starts hard I would check that first. My 38 G will start on the 4th or 5th turn of the flywheel after sitting in the shed for 2 years. If your fuel is good (you can open the drain in the bottom of the carb to check) then check plugs. My guess would still be a weak spark from mag.
Steve
07-20-2003 06:20:02
 Re: Re: Hand Staring B in reply to Dan, 07-19-2003 19:44:24
I have a 41 B When this problem occures it is one of two things a fouled plug on the side away from the fly wheeel or rust in the carb keeping the cylinders from getting gas. check the intake screen first if that doesnt work try the jet those holes are small and easy to plug. Steve
