Adapting hydraulic connectors
DRL
07-19-2003 14:39:31
I have a '48 B with power trol and shear washer type of hyrdraulic connectors. I am wanting to find the best way to adapt my tractor to use the modern type of connectors. Is there a way of plumbing new fixtures on the power trol body? I am sure that some of you have had experience with this. Is there possibly an adapter made that plugs into the existing connectors? Any help is apprecieated.
mark
07-20-2003 10:15:47
 Re: Adapting hydraulic connectors in reply to DRL, 07-19-2003 14:39:31
If you can find a later Power-trol it will bolt right up to your current rear end housing. Thus eliminating the shear type plug.
Cragi
07-19-2003 15:41:25
Do like the rest of us, just use a pipe nipple to attach a Pioneer or your favorite style coupler to your existing plug with shear washer. Simple.
DRL
07-20-2003 00:28:17
 Re: Re: Adapting hydraulic connectors in reply to Cragi, 07-19-2003 15:41:25
OK, are you talking about the actual "plug" that you would normally put on the end of the hydraulic hose? If so, I do not have these, only the dummy plugs. Only "plugs" I have found at salvage yards are not useable; and on ebay or online stores a little too high for my liking. Maybe I'm too tight. Was looking for an alternative to purchasing these "plugs." If I purchase the "plugs, I may as well put them on the end of the hose and be done with it. Any other suggestions, or is the the best/only way.
Thanks.
Cragi
07-22-2003 21:59:26
 Re: Re: Re: Adapting hydraulic connectors in reply to DRL, 07-20-2003 00:28:17
Yes, you got it. But you do not have those plugs.
If you do purchase the plugs I would put some Pioneer or other style couplers on them anyway. Those JD plugs and hose ends cause a LOT of oil loss every time you take them out and in. With some other modern couplers you only loose a little oil each time because of the ball and spring that plugs the hole when you take them apart. There is one other option but I don't know if your shear-washer type Power-Trol has it or not. The later ones have 2 big pipe plugs in the right side that can be used to connect some modern couplers. Start a new post if you have more questions. This one is lost so far down the list that me and others will not be able to find it anymore.
