JD 2020 with growling hydralic pump
Kevin
07-18-2003 19:40:19
I have a question for the JD guru's. I have been a Farmall person since I knew what a tractor was, But this 2020 gas late 60's model caught my eye the other day. This fella is wanting to sell it, but I haven't a clue what its worth. The tin looks decent, and the wildlife and parks owned it before him. He say's that it has 3000 hrs on it and is 33hrs out of a new rebuild. (bearings, rings, sleeves) Although he did not get the valves done. The tractor runs fairly smooth, starts right up. It deisels a little at idle, he claims that he hasn't got the timing just right on it. I don't know. The tractor dosent smoke a bit. It has been sitting along th road a while. You can tell from the dead spots from where the tires have been sitting. No dead grass from oil leaks, None. Their isn't a leak under this tractor. To my question. When it is running it sounds like the hydralic pump growles. Is this normal noise?? The steering works great. Breaks work well. And transmission seems to work well also. He is asking $6500. Please assist. :)
Kevin
07-20-2003 09:58:37
 Re: JD 2020 with growling hydralic pump in reply to Kevin, 07-18-2003 19:40:19
The noise seems to be fairly consistent. I could not tell you if it is a four or eight piston pump. I lowered and raised the three point, it operated smoothly. Also when I turned the tractor from left or right there was no change. Although there was no load on it. Say its a worse case cenario, what would the damages be if it were needing overhauled, or replaced??
Another note, the steering wheel had alot of play in it until I started the tractor. Then the slop tightened up. Is this also cause for concern?
Thanks for the responses!! :)
Trusty
07-20-2003 05:48:05
Does the noise go away or change when you raise and lower the three point hitch? It may just be an adjustment. Is it a 4 or 8 piston pump? Also check the coupling between the pump and engine.
2020RWF
07-19-2003 18:57:37
i got one that sounds the same let me know what you find out
