Heavy Bushhoging today........
Tye
07-18-2003 16:38:18
I stalled my 50 when I was bushhoging my garden that didn't grow. I hit the rut I made when I attempted to plow a few months back. Am I hurting the old girl when I stall her like that? I know I am not doing it any good but I hope I am not shortening her operating life....
John Van Valkenburgh
07-20-2003 22:34:52
 Re: Heavy Bushhoging today........ in reply to Tye, 07-18-2003 16:38:18
I've got a 50 that among other things pulls a 3 blade estate mower. I've only stalled it a couple of times under load. I'd think that a lot depends on how the load on the engine is distributed when it stalls out. If for example you are in 5th and pulling a bush-hog and it stalls out in the tall grass then the load is not all on the PTO. If you were in 1st or 2nd and full throttle and then it stalls in the tall grass then there is a lot of load on the PTO and that (in my opinion) is a lot of stress in one area.
Stalling out under load should not do anything particulary bad to the engine. It simply slows down until it does not support combustion. The thing here is that stalling it out suggests that you are working the machine under loads it is not designed to support.
So...
If it just stalls out on rare occasion when you've got it in a higher gear and a rut catches you by surprise then I would not think that would be abusive. If you are in a low gear wide open (governor running it wide open) and it can't support the PTO load then you are running it "over budget" and it will certainly wear it out prematurly or possibly cause a breakage somewhere.
I think the post suggesting a "slipping" clutch for the PTO is a good idea. Sudden "shocking" loads to the PTO or drivetrain are hard on the gears.
Take care of that ol' 50. Its a great little tractor.
John
johnny
07-18-2003 18:14:50
i have a 44 A been using it to cut the pasture for 25 years now... busted up 3 bushogs with her already but she never gets a scratch, if you break it fix it!! but for god sake dont just let them sit in a barn...USE THEM THEY WILL LAST LONGER!!!!! !!!!
Henry J
07-18-2003 17:47:51
Tye
Yep you are putting her to the test. Something that the ole gal may have took in stride when new, but after a few decades it deserves better. You never know it just may keep on ticking and ticking. If it was mine i would try to find a way to not do that. Just my two centagos.
ChuckW
07-18-2003 17:25:21
about the worst think you could do to tractor...you're transmission/pto want take much of that. Be sure to run a slip clutch on the bushog...not just and override but a good slip clutch.
