My grill for the A won't fit back on right!
john m.
07-18-2003 15:01:17
I am fixing the dents in my grill and it just won't fit back on snuge at the bottom like before. The holes line up but the bottom just won't. Is it supposed to be the same size bolt that goes on the radiator as the rest? Any help or ideas? I probably need to find another A to look at.
will
07-19-2003 16:25:28
 Re: My grill for the A won't fit back on right! in reply to john m., 07-18-2003 15:01:17
if you loosen the big bolt that holds the hood and gas tank on under the instrument panel you can move the hood around where you need to get the bolts in the front but.....dont remove the rear bolt!! just loosen it!! that will give you much more movement then once you get all the front bolts in tighten that big bolt last..
F-I-T
07-18-2003 16:36:17
John:
Not sure of your year, but for late ones, all the bolts for the grilles are 5/16". 1/2" in the three holes in front, 1" for the two in the sides.
Frank-in-Tallahassee
70D // 855
Ralph-WI
07-18-2003 18:24:56
 Re: Re: My grill for the A won't fit back on right in reply to F-I-T, 07-18-2003 16:36:17
On my '50 A there were some spacers on the bolts that fasten to the back of the radiator. I had new bolts from correct connection and they also provided some antivibration dampers(?) on the bolts to tha radiator. Seems to me that my mechanic-consultant said they fit better if one set is left out.
