Gas vs. all-fuel
Dan
07-18-2003 13:14:21
What physical differences would there be between a gas std 70 and an all-fuel 70? Not quite clear on this.Thanks.
how many all-fuels left?
07-21-2003 18:56:51
 Re: Gas vs. all-fuel in reply to Dan, 07-18-2003 13:14:21
Wondering how many people on this site have an all fuel tractor of the first numbered series? I have a JD 70 all fuel rowcrop and dont know how many are left out there that arent junked....anyone got any input? Are any models more collectable than others?
thanks!
Clooney
07-18-2003 17:23:03
Dan, there is a big difference between the 70 all-fuel & 70 gasoline tractor in the engine department.
~The 70 all-fuel carries the bigger engine size [412.5 CI] of the "G" & the gasoline engine was downsized to [379.5 CI] to improve fuel economy.
~The all-fuel had a 6-1/8" X 7" bore & stroke & the gasoline had 5-7/8" X 7" bore & stroke.
~The cylinder head, cylinder block & pistons were different between the two engines, as well as the intake & exhaust manifolds & carburetor.
~Most of the mentioned parts are not very interchangeable.
~The compression on the all-fuel was 4.5 to 1 & the compression on the gasoline was 6.1 to 1..
~As you can see there was a big difference between the two 70 tractor engines & the price of the all-fuel parts reflects that difference as some of those all-fuel parts are getting pretty rare..
John T
07-18-2003 16:05:04
Dan, the "Standard" tractors are low slung and have a heavy wide front end. They look more like orchard tractors than row crop models. As far as gas versus all fuel, their differences are an all fuel carb, a hot manifold, dual tanks (a small one for gas to start and a larger main one originally used for Distilate) and a 3 way switch over valve (gas or distilate) on the all fuel models, plus they were slightly lower compresion to prevent pre ignition on the low octane distillate fuel. Standards are a totally different look and style tractor, while all fuel versus gas only refers to the engine and carb etc as described above, regardless what model tractors they are in. John T
