Installing a JD 60 Main crankshaft seal
Ray
07-18-2003 12:56:35
I am installing the main seals on the right side of a 1956 60, the I @ T manual I have states that two seals should be installed back to back with a 1/16 inch gap for the oil return hole to function properly. On the bearing housing I have the oil return is on the inside side and if two seals are used they must be touching each other in order to fit in to the space. I am thinking that I should put the two seals without a space as the oil return hole is still about 1/2 exposed on the inside side of the inside seal.
