800 series hitch
Wayne Bishop
07-18-2003 11:30:25
I have a 1955 JD 60 with a 800 series hitch. How do I know which one it is and what is the difference? The brackets are still on the tractor but the upper arms are missing. I found some odds and ends (unfortunately nothing complete) at the 2 cylinder expo in Canadaigua, NY last week and also found 2 different length arms. I didn't know what length I needed. Can you help on the correct length and where could I possibly find some?
Also looking for a 4"x16" reversing solid front rim.
Thanks
Wayne
JDVan
07-18-2003 12:22:35
 Re: 800 series hitch in reply to Wayne Bishop, 07-18-2003 11:30:25
third party image
yes, the upper arms do come in two slightly different lengths, even though they look much different. The cast couplers are quite different depending on which threaded rod is used. The 1" longer adjustment upper links were used on the 800 and 800a hitch. The 1" shorter adjustment range was used on the 801. Both will work adequately on all three hitches assuming the appropriate coupling castings are used. A Parts catalog would be helpful and they are available from JD Pubs. This parts catalog shows all three versions of the 800 series hitches.
I have several pictures of the 800 series hitches posted on a public site. See:
Link
