Clutch bolt '49 JD B
RayP(MI)
07-18-2003 10:23:34
Suffered a failure on one of the 3 bolts in the clutch assembly that you adjust the castellated nut on to adjust clutch tension. I&T shop manual shows this as part #32, and calls it an "operating bolt" (serial no. of tractor 2578**.) Dealer gives me a part #B2353R and a price of $47.51 ea. HOLY COW! Is this the right item, and why in the world so costly? How do I get into the clutch far enough to replace the thing? Shop manual not real clear about it.
Clooney
07-18-2003 11:08:46
 Re: Clutch bolt '49 JD B in reply to RayP(MI), 07-18-2003 10:23:34
Ray, that sounds like the right part. That bolt has a "T" head on it & Deere probably has them made in a small job shop so the cost is high. ~You might want to call a local tractor scrap yard to see if there are any used ones. Those things would be cheap if the clutch pulley is already apart. ~Actually you would be better off with a used part as the wear would be closer to the other 2 that are in the tractor.
~If you replace one with new you really should replace all 3..
~To replace that operating bolt you will have to pull the clutch pulley off the tractor, that involves pulling the 4 bolts & removing the front fork bearing & fork shaft, then unbolting the clutch driver & pulling that off [be sure to mark it's position in relation to the crankshaft before removing]. Once the pulley is removed the operating bolt will come right out after the cotter pin is pulled.
~You probably should re-pack the pulley bearing while it's off...
RayP(MI)
07-18-2003 19:56:35
 Re: Re: Clutch bolt '49 JD B in reply to Clooney , 07-18-2003 11:08:46
Thanks, Clooney, Looks like I got some work ahead of me. I'm wondering if I'll have to pull the wheel too, or if I can just move it out on the axle..... what a mess! some days you can't make anything but a bigger hole! (Won't tell you what else went down today, but I finished baling at 10:00pm, and that Farmall 200 won't hold a candle to the old "B" on the baler!)
Craig
07-18-2003 22:08:12
 Re: Re: Re: Clutch bolt '49 JD B in reply to RayP(MI), 07-18-2003 19:56:35
yep, just move the wheel out far enough to get the pulley/clutch off. Depending on which way your wheel hub is on.... instead of trying to move the wheel on the splined axle...it might be easier just to remove the 6 bolts that hold the wheel to the hub if your wheel is bolted to the outside of the hub. If it's the other way around it won't do you any good.
RayP(MI)
07-19-2003 16:08:19
 Re: Re: Re: Re: Clutch bolt '49 JD B in reply to Craig, 07-18-2003 22:08:12
Craig, Wheel is mounted wrong, only choice is to slide it out or slide it off! Son recently did a restoration on this one, and keeping the wheel tight on the axle has been a problem, so sliding it shouldn't be too tough. I have a large wheel puller, which should help. Taking the wheel off and getting it lined up and back on is a little like work however!
