B governor questions....
Tyler-MP
07-18-2003 08:08:25
I've got quite a bit of noise in my governor housing on my 51' B. I'm wondering if I can remove the cover with 4 bolts on the flywheel side without screwing anything up. Can I do this...replace the bearing on the end and reassebmle without removing the whole governor housing? If not replacing bearing at least to inspect inside. Thanks for any information. I know...I need to invest in a B repair manual.
mark
07-18-2003 13:43:32
 Re: B governor questions.... in reply to Tyler-MP, 07-18-2003 08:08:25
you will also need to remove the dist. or mag before you disassemble or you could risk damaging the mag or dist. when replacing the cover. that shaft is spring loaded.
Deere Heaven
07-18-2003 09:59:06
Yes you can remove the cover inside you will find the fan shaft gear is on a shaft. On the shaft there will be a bering and to throw weights on a brass bushing. Check the bushing for wear, and ensure the weights are moving freeley. Thanks, Brian Nielsen
