3020 synchro-range [secret?]
Huckleberry
07-18-2003 06:29:18
just a tip I discovered....have found that [I guess] a common problem with the s-r tran ~ the synchronizers begin to go and won't engage in gear...I was desperate. I really needed 3rd gear bush-hogging some tough CRP. I find that if I move the shift handle into 1st reverse and then back up into 3rd, she will go. I am wondering if I can fix this problem without breaking the tractor in two?...that is ...maybe the synchronizer isn't bad? but the linkage just needs adjusting?...I haven't removed the cowl but don't see any real visible problem down below on the side where the linkage hooks in. This 3020D only has something less than 5000 hours...just a tip for anyone with the same problem.
3-b
07-18-2003 11:13:07
 Re: 3020 synchro-range [secret?] in reply to Huckleberry, 07-18-2003 06:29:18
You have a linkage problem. I have owned several 20 series tractors and this is common when they have around the number of hours you are talking about. It could be anything from a groove worn in your shift stick to one of the two rods that go from shiftbell to the side of your transmission
could need adjusting. I would look futher befor breaking the tractor in half.
wolfy
07-18-2003 18:22:48
 Re: Re: 3020 synchro-range [secret?] in reply to 3-b, 07-18-2003 11:13:07
On our 3010, you can actually rock the tractor back & forth a little by struggling on gear shift lever trying to get it into a gear. Notice if you can get it into any gear, you can then change to another if tires are rolling a bit. If you pull up to gate in 5th, dismount etc, when you get back on tractor you better go for 5th, get it moving then go for what gear you want. It has 3500 hrs & it has been this way since 2800 hrs.
Mike J
07-19-2003 13:32:56
 Re: Re: Re: 3020 synchro-range [secret?] in reply to wolfy, 07-18-2003 18:22:48
This tractor needs to have the clutch adjusted or it is possible that someone put a perma clutch in it if the tractor is in neutral and you push the clutch down after a second or so you should be able to pull the shift lever in gear with no tire movement if it tries to creep the clutch is not releasing.
mike
07-19-2003 21:18:24
 Re: Re: Re: Re: 3020 synchro-range [secret?] in reply to Mike J , 07-19-2003 13:32:56
I don't think you can put perma clutch in 3020's , these clutchs were for 30series and newer tractors , wet clutch set up wasn't used in 3020's
Mike J
07-20-2003 08:02:40
 Re: Re: Re: Re: Re: 3020 synchro-range [secret?] in reply to mike, 07-19-2003 21:18:24
I got a 1969 4000& 1971 4620 both have a perma clutch in them and at RPM higher then an idle they are hard to shift they become magnetized and don't want to release you need to run the free travel about 1 \2 of normal specs . most of them are a little grabby at higher RPM also on the 4620 sometimes we even had to slip it a little just to get it to shift the rest of the day . they both have lasted real good but JD has had lots of shifting complaints because of them They are diffrent then the wet perma clutch and I'm not sure you can get them any more but if you ask a dealer I'm sure they can tell more about them
