JD 6-volt battery
tom
07-18-2003 03:43:41
Gentlemen,
What causes the white/off-white crust to form around the edges of my battery? I do not have any on the terminals, but on the top of the battery holder, and mid-way down on the side of the battery holder bolt too. Is there a way to prevent this?
Thank you,
tom
tom
07-20-2003 05:56:21
 Re: JD 6-volt battery in reply to tom, 07-18-2003 03:43:41
Thanks Deere-Heaven & JOhn-T, that helps!
John T
07-18-2003 06:50:09
Tom, when a battery is charging, especially if its overcharging, or if a cell is going bad, acidic gaseous vapors can rise out the top and react with metals or other components in the presence of oxygen causign that build up you described. When sealers or protectants etc. are used, they reduce oxygen and vapor contact and help eliminate the problem. If a battery is beign overcharged and out gassing a lot, the condition can worsen. I would check the charging rate and clean then lube or coat the items producign the build up and see what happens. On the terminals I like the felt washers plus the spray coating and on other components you might try protective coating sprays or even ignitiion sealer spray after they have all been thoroughlly cleaned of any acid or corrosion. John T
Deere Heaven
07-18-2003 06:25:26
I am not sure what causes this but you can use a product called NOCO. This is a coating that you spray on terminal to prevent corrosion. Brian Nielsen
