JD 4400 stalled
whitedvm
07-17-2003 20:57:57
Combining wheat today and diesel engine stalled. Checked sediment bowl and changed fuel filter. There appears to be fuel getting to roosa master injection pump. Engine will not start. Talked to mechanic on phone, says I got air in lines when changing fuel filter and to keep cranking engine. Any other suggestions? Thanks
Mike
07-18-2003 04:45:12
 Re: JD 4400 stalled in reply to whitedvm, 07-17-2003 20:57:57
If you do have lots of air in system you might
have to loosen the line to each injector then crank to bleed air out.Tighten up then try to start it.
