Mod. A sucking oil out of crankcase
chuck
07-17-2003 07:41:28
I am working on a 1950 Model A serial #663272. It has been setting for about a year. The problem is that after it ran about 1/2 hour is started sucking oil out of the motor.I removed the breather tube that connects to the houseing that drives the fan. That stopped the smoking. With the breather disconnected it does not suck oil and under a pull there is no smoke coming from the breather hole in the motor. I was told the tractor has been worked on but not by myself so I don't know what was done and I have not had a JD motor apart before. Does anyone have a idea what could be wrong.
JDBert
07-18-2003 07:20:53
 Re: Mod. A sucking oil out of crankcase in reply to chuck, 07-17-2003 07:41:28
chuck, my A did this after I totally restored it and the only gaskets I didn't replace were those two gaskets on the ventilator pump I tore the fan shaft out replaced these gaskets and that stopped it. Mine was sucking it into the carb, man did that thing smoke. If memory srves me right the gaskets also serve as shims to get the fan shaft gear back lash right.
F-I-T
07-17-2003 08:11:19
third party image
Chuck:
You probably have a sticking/stuck/worn crankcase ventilator pump vane. This is located at the base of the fanshaft next to the governor housing. You'll have to remove the fanshaft to repair it.
Now, if you don't want to R&R the fanshaft pump right now, you can drill a hole in the pipe nipple where the engine oil is added. This will remove the pressure without so the oil doesn't force itself into the carb intake. Somtimes this will do the trick until you can tear it down.
Loosen the filler cap and see if this corrects it. If so , you can drill a small, say 1/8" hole if you decide to repair it later.
Frank-in-Tallahassee
70D // 855
chuck
07-17-2003 14:32:57
 Re: Re: Mod. A sucking oil out of crankcase in reply to F-I-T, 07-17-2003 08:11:19
I though there must be something in there. Will the fan shaft come out with out removing the radiator. Thanks for the help
ravgardner
07-17-2003 17:57:16
 Re: Re: Re: Mod. A sucking oil out of crankcase in reply to chuck, 07-17-2003 14:32:57
Chuck,
Remove the antifreeze, fan cowling, then the top and bottom radiator hose. Remove the bolts under the radiator that hold it in place. With some help, I leaned the radiator foward againts the steering pedestal that gave me enough room to lift the fan up and off. Good luck.
F-I-T
07-17-2003 15:10:34
Chuck:
I can't rightly remember. I know a lot of radiators have been nicked by the end of the fan shaft. I think you have to move the radiator forward as far as you can.
Someone else here will be able to answer it for you. It's just been too long since I repaired that on our '48, #595871.
70D // 855
Ravgardner
07-17-2003 12:25:59
F-I-T Thats a great diagram Frank. Where did you find it? We have been trying to figure out a 47 B that is pumping oil out of the front of the fan. Its ventilator outlet pipe has been disconnected from the air intake elbow. The pipe connection on the entake elbow has been plugged and the ventilator outlet pipe cut. Why would someone do that? Where can we find diagrams for the pump and explanations of how the vent systems work on the 47? We noticed that Deere changed the vent system again in 48. Why did they change it?
F-I-T
07-18-2003 07:00:58
 Re: Re: Re: Mod. A sucking oil out of crankcase in reply to Ravgardner, 07-17-2003 12:25:59
Rav:
I think you have the same problem. I think the vent pump failed, and they pinched off the pipe in hopes of preventing further movement of the oil out of the fanshaft and into the card air intake pipe. Now the oil has filled the fanshaft pipe for so long, the little felts at the fan end can't hold it back any more.
To fix it, you have to R&R the fanshaft pump, and re-place the front end felt. Re-pack the bearinggs (it won't take much), and you should be good to go.
Not a costly job, but a big one noe the less. In the mean time, might try removing the oil filler cap and see if the oil flow out of the fan area stops.
Frank
F-I-T
07-17-2003 13:10:14
Rav:
Send me you e-mail address and I'll tell you where to get the diagram.
Frank
[email protected]
