Is this ring gear too worn out?
Mike
07-16-2003 19:32:00
Here's a photo of a few of the teeth on the ring gear for a 48 A. I'm having trouble getting this gear to mesh with the drive gear on the starter - often times they grind together. Given its condition, can the teeth be cleaned up to work OK or am I going to have to remove the gear and flip it over? I'm not sure what a worn set of teeth look like, so please help out if you can. If they can be cleaned up, how do I go about it?
third party image
Clooney
07-17-2003 04:03:07
 Re: Is this ring gear too worn out? in reply to Mike, 07-16-2003 19:32:00
Mike, those teeth look pretty good. You probably should try a new starter drive on the starter & look at the starter for loose bolts, worn bushings, & the nose housing for wear & cracks.
~If the new starter drive still won't mesh correctly you will then have to use a grinder & remove that tooth end burr & maybe chamfer the tooth lead in a little more.
~Those ring gear teeth are not worn at all, just a little burr on the ends of the teeth. On a worn ring gear the teeth will be about 1/2 missing in the worn section.
~You really need to get your problem repaired now as those teeth won't last long if it's grinding..
MPK
07-16-2003 19:54:41
From the looks of that gear it makes me wonder whether maybe your trouble is coming from the starter drive not wanting to slide over and engage. I would think that if the starter drive is ok, the flywheel gear is good enough.
