Galvanized Sheet Metal On Rice Tractors
DHunt
07-16-2003 06:20:29
The July/Aug edition of Two-Cylinder has several pictures of rice tractors with "galvanized" sheet metal. I'm assuming this was done to an otherwise standard JD tractor by its owner or a local shop. Does anyone know more about how they accomplished this, or what the process was? My R has rice and cane equipment so I always have an eye out for them, but have never seen a galvanized one on display.
F-I-T
07-16-2003 08:31:40
 Re: Galvanized Sheet Metal On Rice Tractors in reply to DHunt, 07-16-2003 06:20:29
They described the origin of the galvanised sheet metal in the caption under the photo upper left, page 8:
"Model "R" with all the sheet metal galvanized. Steve Kole started the galvanizing procedure because of the corrosion problems caused by high salt content in the soil and air. Their farm was south of Winnie, Texas, close to the Gulf of Mexico."
Frank-in-Tallahassee
70D // 855
DHunt
07-16-2003 15:21:43
 Re: Re: Galvanized Sheet Metal On Rice Tractors in reply to F-I-T, 07-16-2003 08:31:40
Yes, I understand the reason behind it. I was just wondering if anyone had experience with doing it themselves. Is it home grown chemistry or were the parts taken out to a commercial shop. I'm always curious about ways farmers improvise machines and tools to fit their needs and this looked like an interesting example.
F-I-T
07-16-2003 15:28:31
 Re: Re: Re: Galvanized Sheet Metal On Rice Tractor in reply to DHunt, 07-16-2003 15:21:43
DHunt:
Galvanizing can be accomplished by either "Hot Dipping", electroplate, or cold treating (least long-lasting. "Hot dipping" is the most common.
I would imagine he took the parts to a marine treater on the coast. Lots of steel boat cabin parts are treated this way today. If he knew of a galvanizing roofing producer thay could have done, too.
I doubt he did it himself, because you would need a pretty big tub of molten zinc to accomodate an "R" hood. Unless he a hot-spray rig, again doubtful. The fumes from that process are pretty toxic.
Frank
Brandon
07-16-2003 07:53:07
It must have been some farmer modification (of course, you never really know for sure!)
I've got a Rice 80, and when I sandblasted it, none of the metal was galvanized. Of course, the paint probably wouldn't have stuck to it as good!
Brandon
My Industrial John Deere website
My JD model 80 website
The LaGrange Engine Club
