Model 111 Lawn Tractor
No Spark
Barry
07-15-2003 17:39:10
My 111 just quit while mowing the lawn and it seems to have plenty of gas. I cleaned the plug and put the wire back on but can't determine if it is getting spark.
Can anyone lead me through the diagnostics to determinbe if it is getting spark? If no spark, then what?
Thanks!
leon
07-16-2003 04:23:46
 Re: Model 111 Lawn Tractor - No Spark in reply to Barry, 07-15-2003 17:39:10
When worling by myself with no one to hold the plug wire while the engine is cranked, I find a good way to check spark is tp pull the spark plug out, reattach the plug wire, lay the plug somewhere on the tractor where there is a good ground, then in a darkened place crank the engine. If there is no spark visible at the plug gap, the flywheel will have to come off. Kohler /JD had an electronic ignition kit for those engines. It costs less than the parts for the original condenser/coil/point system and lets the engine run a whole lot better. Good luck.
