Adding Cold-air to old heated cab?
Textrout
07-15-2003 10:09:44
Can someone here tell me if I can add a air-conditioning unit to a heat-only cab? It's an old early 70's model 2040, a northern tractor, with heat only.... but I'm in Texas and need AIR!
What are my option and what would it cost to convert it? Aftermarket products available?
Thanks a million for your help!
wburt
07-16-2003 11:57:51
 Re: Adding Cold-air to old heated cab? in reply to Textrout, 07-15-2003 10:09:44
Sears and J.C. Whitney used to make self contained units that fit under the dash of cars. I once took one of these and put in a 6600 jd combine and it worked as good as factory. Might go to a salvage yard and get ne out of an old combine 4400 or 6600 and put in your tractor.
