Transmission on '49 B
Barry
07-14-2003 19:05:05
My trans. is stuck in a gear no matter where I put the shift lever it's in a gear, no neutral, no reverse always in same gear and can't get it out. Where do I start looking and what do I look for.
Thanks,
Barry
Clooney
07-15-2003 03:20:52
 Re: Transmission on '49 B in reply to Barry, 07-14-2003 19:05:05
Barry, the place to start is by pulling the top trans cover. For some reason one of your shift rails is moved to engage a gear & the shift lever didn't go with it. The shift lever is now behind the engaged shift rail. ~You should be able to just line all the shift rails back up in the neutral position & reinstall the trans top cover.
~It probably happened due to weak detents, or trans wear, & a hurried shift. If you use a slow deliberate shift between gears it probably won't happen again.
