JOHN DEERE-H OPERATING TEMP.
H-OWNER
07-14-2003 16:24:06
WHAT I NORMAL TEMPERATURE FOR A JD-H ON A SUMMER DAY RUNNING NORMAL SPEED UNDER AVERAGE LOAD?
JDVan
07-15-2003 11:52:28
 Re: JOHN DEERE-H OPERATING TEMP. in reply to H-OWNER, 07-14-2003 16:24:06
There are a lot of variables that need to be defined to answer your question. However, the one variable that would control the temperature the most is the shutters. Where are you setting them during this time? I own two H's, a1941 and a 1942. On both I have trouble getting them to operate at above 180 degrees in warm weather and under a light load. Even with the shutters closed.
Are you having trouble with it running too cold or too hot?
Will P
07-14-2003 21:09:57
Thermosyphens will run on straight water at about 200 degrees. Running 50/50 water and antifreeze it will probably run around 230-240 degrees.
Will P
