Drive shaft play on my 50...problem??
Tye
07-13-2003 16:09:51
In taking things apart, the drive shaft in which the two gears underneath the first gear reduction cover are on (transmission gear and pto gear) I noticed that the drive shaft is able to move in and out slight, about 5/16." My question is, is this normal? I put the reduction cover on onnce and I was able to slide the transmission gear far enough outward to actually scrape the side of the reduction cover. Should I be worried about all this or is all this normal? Again, this is on a 1953 model 50. Thank you for any advice. Have a great day.
Clooney
07-13-2003 17:07:46
 Re: drive shaft play on my 50...problem?? in reply to Tye, 07-13-2003 16:09:51
Tye, the outer input shaft bearing [the small one under the outer cover] is what controls the input shaft end play on the 50. If you haven't installed the outer bearing & cover [including the snap ring] there will be a lot of lateral movement of the input shaft.
Thank you Clooney!!
07-13-2003 17:40:23
 Re: Re: drive shaft play on my 50...problem?? in reply to Clooney , 07-13-2003 17:07:46
Thank you so much Clooney!! You're a life saver!! You just answered more questions than the few I had written down, thanks again!!! --Tye
