John deere 47-52 model b
john
07-13-2003 14:36:57
on the b there are two square shafts on the back of the seat is this for three point? how does the power trowl work? is there a draft setup? also will b run a jd 14t square baler? the b that im looking at has what looks to be remotes on the back but there capped off??? is this right?
C
07-13-2003 18:43:03
 Re: john deere 47-52 model b in reply to john, 07-13-2003 14:36:57
Sounds like you need the operators manual for that tractor. The Power-trol works when the PTO shaft is running. There is a built-in hydraulic pump on the back of the tractor. You can set up the Power-trol to operate the rockshaft (those square shafts) OR to operate a remote hydraulic cylinder. It can not run both at the same time. Operators manual will tell you how to set it up. There is no draft control. The rockshaft was mainly intended to lift a cultivator and other attachments.
I ran a 24T behind my 1950 B on level ground so I would think a 14T would work just fine too.
Jerome
07-13-2003 17:22:00
John,
We used ours for a 3pt hitch assembly, though I do not believe the JD ever made one especially for the B. We also used them for the cultivator and I think even the 509 mower we had and a couple of other pieces of equipment. The remote hookups on the back are exactly what you think, they have plugs in them and can be turned and removed to expose the power take off hydraulics.
Good Luck with it. Jerome
