Early styled B Weight
Phil
07-13-2003 12:47:59
Bought a early Styled B short frame year ? has the angle iron front rails not the pressed steal I would like to know the weight of this tractor
thanks Phil
gwh
07-13-2003 13:40:55
 Re: early styled B Weight in reply to Phil, 07-13-2003 12:47:59
Phil, What is an "early Styled B short frame"?
Bill
07-13-2003 20:46:56
 Re: Re: early styled B Weight in reply to gwh, 07-13-2003 13:40:55
The early model B had a shorter frame than the A,,,,Later they made the frame longer ,,approximately 1939...????? so the same imple ments would cross from the A to the B ,,,,, Bill
gwh
07-14-2003 21:15:18
 Re: Re: Re: early styled B Weight in reply to Bill, 07-13-2003 20:46:56
Right, but the change from short frame happened in '37 at serial number 42,200 during the unstyled era. So no "early styled short frames" from the factory. I'd venture to guess Phil's tractor is a '39-early '47(but not the '43-'44 with the cast front support) With out knowing the wheel equipment i would guess his tractor weighs 3,500-4,200 pounds
