4020 triple hyd remotes
ToddWISCAL
07-12-2003 16:54:43
I have a '69 4020 equipped with dual remotes and would like to add the third remote setup. What do I need? Any tips on where I may locate a setup? I have not been able to look over a tractor with this setup and a parts book is still on my wants list!
davidval
07-13-2003 00:45:12
 Re: 4020 triple hyd remotes in reply to ToddWISCAL, 07-12-2003 16:54:43
if you need the extra scv just for a certain job, you should consider a generic 2 spool scv connected to one of the tractor's scv's. could proove to be a lot cheaper.
david
Mike J
07-12-2003 19:29:39
68 is early model 69 is late and has side consol by seat
4020
07-12-2003 17:55:41
4020s never were available from the factory with three outlets. You will have to patent an aftermarket kit on the tractor.
Mike J
07-12-2003 19:27:41
 Re: Re: 4020 triple hyd remotes in reply to 4020, 07-12-2003 17:55:41
late model 4020's were available with 3 outlets they just install a plate behind the right hand outlet that is long enough to let you mount another outlet above the one that is there then the side tin needs to be cut.
Todd WISCAL
07-13-2003 08:49:00
 Re: Re: Re: 4020 triple hyd remotes in reply to Mike J , 07-12-2003 19:27:41
I have a '69 with the side console. is the third remote housing the same as the others? the sheetmetal has a knockout for the outlets.
