JD-2010 engine
frank
07-12-2003 15:15:03
I have a 2010 , I have rebuilt engine from crankshaft up, I have timed crank and cam shaft, I have fly wheel TDC, have #1 piston TDC on compression, have oil pump looking at #4 piston (as JD technical manual directs) 45 degrees from parallel, put enjector pump in with timing marks lined up with oil pump shaft. Enjector pump and enjectors have been rebuilt. Starter has been rebuilt, new battery. Timing marks on enjection pump are in time. Tractor will not crank at all until you advance the enjector pump all the way clockwise, at that point you can not see timing mark in window but tractor will crank and run but has white puffs of smoke. Also, it takes a shot of ether the first time to start. If I drop oil pan and turn oil pump gear back one gear, then pump bottoms out in opposite direction. PLEASE HELP!
I have tried to follow the JD technical manual but something is wrong.
Hoosier
07-13-2003 04:49:21
 Re: JD-2010 engine in reply to frank, 07-12-2003 15:15:03
Check the injector pump. Could have been put together 180 off when rebuilt. Just had that happen to us with 3020 pump.
