TOE-IN ON 4320 ?
John in Md.
07-12-2003 09:05:52
Narrowed front end on 4320. Thought it should be about 1/4" but it still seems to be chewing the tires. Tired of taking it apart, anybody know? Thanks, John
Lee
07-13-2003 02:56:41
 Re: TOE-IN ON 4320 ? in reply to John in Md. , 07-12-2003 09:05:52
Don't be afraid to go as low as 1/16". Only reason for toe in, in the first place is to 'preload' the tie rod ends so you don't wander all over the road. If you are not wandering now you can lessen it some more. On a working tractor in the feild, zero is just fine.
Turning may be the real culpret here. Often the geometry of the system is set such that in a full turn neither tire is turning in the actual circle the tractor is going. Sometimes one is drastically trying to turn the tractor too much. This requires a mismatch between pitman arm length and drag link length or tie rod to kingpin length. Making them the same length should relieve the situation. Perhaps someone else put on the wrong pitman arm?
Bob
07-13-2003 00:08:34
1/4" sounds right. Could you have a bent axle tube so the caster or camber would be way off?
DEERMAN
07-12-2003 15:27:38
If you have roll a matic make sure the buschings are good. Ive seen them wear tires out fast when they are worn out.
John in Md.
07-12-2003 15:38:23
 Re: Re: TOE-IN ON 4320 ? in reply to DEERMAN, 07-12-2003 15:27:38
No it's a wide front end.
