JD 3010 Fuel pump
Darryl Holtmeye
07-11-2003 12:36:39
Hey guys, haven't been on the forum lately, but I need some help and advise if you don't mind. I had the fuel pump fail on my 3010. It leaked gas into the block, like 2 gallons worth! I got a replacement fuel pump, put in new oil, filter, and the tractor is now fine. I would like to get the original fuel pump rebuilt. JD won't do it. Know of anyone who will?
Thanks
Bob
07-11-2003 13:54:32
 Re: JD 3010 Fuel pump in reply to Darryl Holtmeyer, 07-11-2003 12:36:39
Not sure of your reasons for wanting the old fuel pump rebuilt... the only reason I can think of is that you have a collector tractor and want the "correct" fuel pump held together with screws, instead of the newer ones that are crimped together. Anyhow, you might want to pick up an old car restoration magazine and check out the ads. I think you will find places that have parts or rebuilding services available for old fuel pumps, and probably could match something up for your Deere. It's probaly an AC fuel pump very similar to those used on certain cars.
Darryl Holtmeyer
07-21-2003 08:53:28
 Re: Re: JD 3010 Fuel pump in reply to Bob, 07-11-2003 13:54:32
Bob, Thanks for the response. The real reason I want the old one rebuilt is to keep the glass bowl. I like the idea of being able to see that fuel is there. I'll check some of the rebuild places.
Bob
07-21-2003 22:18:33
 Re: Re: Re: JD 3010 Fuel pump in reply to Darryl Holtmeyer, 07-21-2003 08:53:28
Darryl,
Email me direct, off the board, and I'll email you a source for the original style with the glass bowl.
Michael Fazi
03-11-2005 20:37:55
 Re: Re: Re: Re: JD 3010 Fuel pump in reply to Bob, 07-21-2003 22:18:33
I need a wiring diagram for a 3010 series Tractor John Deer. Do you know where I can get one for very little or no expense?
