630 CARB PROBLEM STILL WONT IDLE
RMAN
07-11-2003 11:59:01
THANKS FOR REPLEY ON OUR 630 IT WILL NOT IDLE WITH OUT CHOKE PULLED OUT SOME JUST SURGES.WE REMOVED SOFT PLUGS ON SIDES USED CARB CLEANER WITH SMALL NOZZLE IN HOLES SO CAN SEE CLEANER SPRAYING OUT WHAT ARE WE MISSING PLEASE HELP.WE TOTALLY DISSASMBLED REMOVED BUTTERFLYS ALSO CAN SEE CARB CLEANER MIST IN ALL HOLES
ChuckW
07-11-2003 12:38:16
 Re: 630 CARB PROBLEM STILL WONT IDLE in reply to RMAN, 07-11-2003 11:59:01
those carb passages are really hard to clean on the duplex. There are passages from the bottom of the carb that feed up to the idle passages. This requires removing the lower cap screws, then removing the main jets, and cleaning up into the passages. I alway use cleaning tip, but even with this it still hard. I always soak my carb in Berryman carb cleaner from Autozone, soak about 1-2 days. This stuff is potent and smelly. Also the way the pros do is to remove the balls from the idle passages, however this is tough. I've always been able to clean without doing this. Just spraying some carb cleaner will not do the trick as it will not loosen the crud. Good luck but try the autozone soaking cleaner, comes in a gallon can and you'll need a larger covered container.
rman
07-11-2003 20:26:13
 Re: Re: 630 CARB PROBLEM STILL WONT IDLE in reply to ChuckW, 07-11-2003 12:38:16
thanks chuck for repley removed carb again used strong lite could see we did not clean out passage on top of where you screw out main jets we used small tip cleaner bits to clean reassmbled runs perfect thanks for the help rman
