HOT AND COLD
WALLACE
01-14-2004 15:29:29
WHY WOULD THE RADIATOR HOSE AT THE BOTTOM BE COLD, AND TOP HALF OF THE RADIATOR BE HOT BUT THE TRACTOR RUNS AT THE CORRECT TEMP.THIS IS A 1020 DIESEL ENG
david val
01-14-2004 23:23:18
 Re: HOT AND COLD in reply to WALLACE, 01-14-2004 15:29:29
that's the way the cooling system works, coolant is cooled while moving in the radiator from top to bottom. in low load/ low ambient temps, the thermostat remains closed (or partly opened)and exludes the radiator from the cooling circuit thus keeping the correct operating temp.
david
Dave / Believer45
01-14-2004 16:04:25
I assume you are running it without a load (bush hog or something that will pull a bunch of power). A diesel at idle and even at decent RPM but not under much of a load will run very cool. A big truck engine can get as low as 130 degrees at idle which is why they are idled up to 900-1200 rpm when they will be idled a while. The radiator dissapates the little bit of heat generated by your engine before the hot coolant gets halfway down the radiator which is why the top of the radiator is warm but the bottom is cool.
If you are not overheating there is nothing to worry about.
Dave / Beliver45
wallace
01-15-2004 15:19:34
 Re: Re: HOT AND COLD in reply to Dave / Believer45, 01-14-2004 16:04:25
thank you, because it just did not make good sence to me. and the only load it was doing was scrapping snow.and yes it does not overheat thank you again
