Carb Model A JD
earle jennings
07-11-2003 02:55:05
what does a tsx-74 carb fit ???? and can i use it on my 48 A JD??
David from Kansas
07-12-2003 18:49:31
 Re: Carb Model A JD in reply to earle jennings, 07-11-2003 02:55:05
A friend of mine had a good used one for sale for a late A. Try Ed at [email protected]
David
Pappy
07-11-2003 23:28:51
You should use a DLTX 71 Carb if it is a gasoline burner or a DLTX72 if it is all fuel. Since you are probably burning gasoline, use the DLTX71.
Mike
07-11-2003 05:57:30
The TSX should be an up draft you would need
a DLTX side draft carb. Don't have book handy to look up # but I think Roberts Carb. web site has
these charts on it.
earle jennings
07-11-2003 09:27:11
 Re: Re: Carb Model A JD in reply to Mike, 07-11-2003 05:57:30
thanks Mike will check in on that web site
