JD 50 smoking problem
Randy G.
07-11-2003 00:30:41
I have a 1955 JD 50 that smokes real bad out the stack. Is there an ajustment I can make to correct the problem? The smoke appears to be white and not blue. It runs fine w/o much engine knocking. If an overhaul is the cure, what would be the best book or tape as to how to overhaul the engineas I have never done it bbut would look foward to the learning experience. Please help!
JDVan
07-11-2003 10:28:46
 Re: JD 50 smoking problem in reply to Randy G., 07-11-2003 00:30:41
If the smoke is truly white you are getting water into the combustion chamber.
1.)There may be water in the gas
2.) You may have a leaking head gasket
3.) You may have a cracked head or block
Are you losing water in the radiator? If not then probably the water is in the gas. Happens quite often due to condensation over the winter. Drain the gas tank and carburetor and put in new.
