620 Lock-up
wolfman
07-10-2003 18:10:38
New to 2-lungers; Have a 620 that twice now has seemed to just lock up. In any gear or neutral if you attempt to engage clutch, you could stall engine- it is tight. The clutch brake is loose, you can turn clutch-side pulley by hand, you can push tractor by hand. It eventually seems to correct itself & you can drive off. Any suggestions? Thanks.
Mike
07-11-2003 05:39:05
 Re: 620 Lock-up in reply to wolfman, 07-10-2003 18:10:38
One possible cause could be worn shifting forks.
When you shift trans. lever from one side across
to the other side go slow and try to feel high low gear actually go in. The same goes for the
indivdual speeds it might be staying partially in one gear while you put it in another. I have seen this alot on various models with lots of hours.
