2510-excessive oil usage
dan
07-09-2003 07:59:02
i have a 2510 thats going thru oil too fast-rebuilt motor and injector pump and had head redone-new injectors-still same problem -not leaking-its burning it somehow-seems to have lot of diesel smoke when lugging on it-checked timing-checked static timing-seems to be right there-goes thru 1 qt /hr at high rpms andlittle or none while idling
Keith Alexander nny
07-10-2003 04:17:12
 Re: 2510-excessive oil usage in reply to dan, 07-09-2003 07:59:02
When our 2510 was redone there was some problem with a breather tube and it ended up sucking oil into the intake. It ended up bending a connecting rod. Did you break in the engine after rebuild if the rings don't seat right this too will cause an excessive oil consumption. Good luck
Larry
07-10-2003 04:13:11
Don't sound like a good deal. I had a tractor that was doing essestially the same thing as yours, turned out it had broken rings on 2 cylinders. Do you have alot of blow by? Mine did.
Mine had been overhauled, but overhauled using the old pistons and liners....ie...new rings and I think the pistons and liners simply had too much wear to work right. The ring lands were way out of specs and I'm sure thats what caused the rings to break. Bottom line. I don't have any advice for you, but I'd guess you've got a problem much like I had.
