JD 24T baler parts
Ron Beauchene
07-08-2003 16:10:55
We are trying to figure out if there is a cheaper way to replace the wear pads and guides on the plunger assembly. A quote of 200 dollars for a piece of flat bar with holes? The wear blocks are 38 bucks each! Not to complain but has anyone tried alternative fixes? It's been shimmed as far as can go.
C
07-08-2003 19:08:07
 Re: JD 24T baler parts in reply to Ron Beauchene, 07-08-2003 16:10:55
Can't help you on that one. I priced some of those parts 12 years ago. Wear guide was $70 back then. Wish I knew if there was anything special about those guides. If it's just plain steel we could make our own. They could be a special alloy and verly slightly surface hardened to reduce wear. I don't know.
