JD 720D pony start fuel gauge
Curt Cooke
07-08-2003 13:10:17
Folks, thanks for the help of this red guy on the pony on this 720D. Turned out to be one fried coil; replaced both. Next question, bought what is supposedly going to be fuel gauge and sender from JD at great expense. The gauge clearly indicates 13.8 Volts. Called JD and they say it will work in my 6 volt environment, are they right? Can it be made to work or should I bail on the idea of having a working fuel gauge?
Curt
Charles
07-09-2003 11:43:19
 Re: JD 720D pony start fuel gauge in reply to Curt Cooke, 07-08-2003 13:10:17
It will work just fine. I put the same $$$ JD setup on my 70D, labeled 13.8v pos ground. The only difference is that it is a little slower reacting when running on 6 volts but it is just as accurate (I tested it on the bench with a variable power supply).
