Cracked 70 exhaust manifolds?
scruffy
07-08-2003 09:42:09
Is it common for the "bypass" exhaust manifold path that runs exhaust to the intake manifold (flywheel side) in the exhaust manifold to crack? My 70 has a crack running from the flow control valve to the intake manifold. The valve is set to not send any exhaust through this passage so it's not leaking.
What are ways to fix this? If it's a common problem (stress caused by binding between head and intake manifold) I assume another manifold will do the same thing.
This is a light duty tractor (log splitter, brush hog, blade snow, hay wracks, etc) so I only need a funtional fix. I realy don't care how it looks.
As always, thanks for your help.
Scruffy
steve corum
07-08-2003 18:50:22
 Re: Cracked 70 exhaust manifolds? in reply to scruffy, 07-08-2003 09:42:09
Hey scruffy, Why is the bypass shutoff. opening up the passage will increase flow and warm your fuel. I bought a 60 same problem. new intake exhaust but opened the bypass. also when you run that tractor hard plowing baling moving dirt etc. it will genorate all lot of heat, after working it. let it cool down by just letting it idle, then shut it off. Yor have to use the cool down methon on turbos or it will burn them up over time. Good luck hope this helps
Dave
07-08-2003 16:45:06
I welded the manifold on my 730 gas 20 years ago and it is still on the tractor.
Dan
07-08-2003 12:39:30
I ran my 70 gas with 1 large hole on each side for 2 yrs. when I first got it,did not seem to have any adverse effects.But I did replace the manifold with a used one 5 yrs. ago and still no problem.
