JOHN DEERE 730 DIESEL
PHILLIP A. FINL
07-07-2003 09:49:15
I RECENTLY BOUGHT THIS 730D. DROPPED THE BIG OIL PLUG. WAITED TEN MINUTES, PUT MY FINGER UP INSIDE AND HERE IS A GREAT BIG FLAT WASHER(APPROX. 1.5" DIA.!). IT WILL NOT COME THRU THE DRAIN HOLE NOR THE SIDE WHERE YOU ADJUST THE OIL PRESSURE. WHAT IS THIS BIG WASHER? IT HAS A CENTER HOLE OF APPROX. 1/2 TO 9/16. MAYBE IT JUST CAME OFF OR BEEN IN THERE FOR 30 YEARS. THANKS, PHIL.
ChuckW
07-07-2003 10:34:31
 Re: JOHN DEERE 730 DIESEL in reply to PHILLIP A. FINLAY, 07-07-2003 09:49:15
can't recall anything with such a washer...probably was dropped there accidentally.
You can pull the inspection plate and use a long magnet and remove.....or put a threaded rod and attach and remove...
