AR Problems Yet
Randy Simmon
07-06-2003 17:52:26
First of all I want to thank the guys that responded to my last message about the vibration that I was having. My cluch was out of balance and I have got that little problem fixed. Now I have a bigger problem. I'm leaking water into the crankcase. The water seems to be coming out of the tubes that the push rods go through. It also is leaking out of the two outside pushrods also and there are no tubes in them. The tubes seem to be brass not steel. I had the head checked out to see if it was warped and it was not, but I know that I'm going to have to take it off and this time I'm going to have it milled for flatness. But my guestion is if I have to put new brass tubes in it how do I replace them? Also should I take the block off again and have that milled? I hate to have to tear it completely down again but if that is what I have to do I will do it. If anyone have any advise on that I would like to hear it. Thanks Randy Simmon
mark
07-07-2003 07:23:47
 Re: AR Problems Yet in reply to Randy Simmon, 07-06-2003 17:52:26
just remove the head and replace the pushrod tubes.
Earl S.
07-06-2003 19:02:41
What year is your AR?? Did you by chance drill out some broken manifold studs?? Earl
