JD 400 Lawn Tractor Stalling
SE
07-06-2003 08:25:10
I have a 1979 jd 400 lawn tractor and it begins to stall after using for awhile. I think it is
overheating. Any help resolving this would be appreciated.
Thanks
720diesel
07-07-2003 19:51:20
 Re: JD 400 Lawn Tractor Stalling in reply to SE, 07-06-2003 08:25:10
if it starts backfiring and cutting out (when it gets hot),you might want to change the points and condensor if you haven't done so already. my jd 400 has done the same thing in the past so then i changed the points and condensor and then it ran great again.it might be worth a try to change those 2 things. hope this helps!
