JD 60 rear wheel bearing -- help.
Sam
07-05-2003 11:04:37
Hello, after haying noticed that the right rear axle outer cover is missing the seal. The metal cover at he end of the axle housing is wearing a groove on the axle. Does this mean that the bearing is bad? Cand this be fixed by removing the tire? Do I have to take the axle out to fix this problem? How many bearings are there on this axle? I am new with JD's and would appreciate all help. Thanks, Sam
Clooney (slow loading pic
07-05-2003 13:09:03
 Re: JD 60 rear wheel bearing -- help. in reply to Sam, 07-05-2003 11:04:37
third party image
Sam, not sure how you can tell the seal is missing without pulling it apart first The outer seal [#12] is actually a felt that goes INSIDE [#13] & can't be seen from the outside. All that felt is, is a DUST SEAL, the actual axle grease seal [#18] goes inside the rear axle housing near the inner axle bearing.
~If that outer retainer [#13] is wearing a slot in the axle shaft, the axle bearing(s) are probably either real loose, or worn out [probably both].
~To replace those bearings, & the inner grease seal, & remove the axle shaft, the whole rear of the tractor has to come off.. Then the inner axle nut [#24] has to be removed, then the axle shaft [#14] pushed out. If done correctly that will also push the [#13] retainer out as the axle moves out. Unfortunately it's a big job & the rear assembly is very heavy & also quite top heavy. The rear wheel will also have to come off..
~BE CAREFUL!!...It's easy to get hurt working with those heavy parts so help is advised..
~Post back with any additional questions...
[email protected]
