Hooking up #8 mower to 44 JD model A
cam
07-04-2003 10:29:43
CAN ANYONE GIVE ME MEASUREMENTS AND DESCRIPTION OF BRKTS TO HOOK UP A #8 SICKLE BAR MOWER TO MY MODEL A? THERE IS NO HYDRAULICS ON THE TRACTOR, THE MOWER HAS QUICK TATCH.ALSO I NEED TO MAKE A FOOT LEVER TO RAISE AND LOWER THE MOWER,ANY INFO ON THAT WOULD BE GREAT TOO. THANKS
popper dick
07-05-2003 06:17:03
 Re: hooking up #8 mower to 44 JD model A in reply to cam, 07-04-2003 10:29:43
Cam,
I have a number 8 mower on my 1950 model B. I also have a JD manual (PC817) which shows all of the various tractor mountings for different model and makes of tractors. The manual also shows the optional mechanical lift bar if hydraulics are not available. You really need this manual and I feel it is still available from JD since I bought mine early this year.
Hope this helps.
Good luck
Dick
cam
07-05-2003 09:16:00
 Re: Re: hooking up #8 mower to 44 JD model A in reply to popper dick, 07-05-2003 06:17:03
thanks guy's! i'll try the john deere dealer to see about a manual, thay should have one since i was able to get a grass board and pitmans for it yesterday. cam
Grass Board?
07-05-2003 19:43:18
 Re: Re: Re: hooking up #8 mower to 44 JD model A in reply to cam, 07-05-2003 09:16:00
You got a Grass Board from your Deere dealer?
What is it made out of? Last time I checked they were no longer available. What is the part number?
Thanks for any information.
Bob
07-05-2003 10:27:14
You can call Deere direct at 1-800-522-7448 and order a manual with a credit card.
Bob
07-04-2003 12:03:06
The owner's manual his pictures and info. I had lost mine, but purchased an original off of ebay this spring. If you intend to continue to use this mower, an owner's manual sure would be a good idea! More than likely Deere still has them available. To get you started, let me know by email if no one else helps, and I would be willing to send you a copy of the attachment brackets page by snail mail.
