830 3 cyl. hyd. noise
fred
01-14-2004 06:41:19
My german built 830 makes a loud shrieking noise from frount pump when clutch is pushed in. With clutch out its fine, 3 pt. works well with heavy load as long as clutch is out. fluid ok, lines look ok , isplit tractor and lines and by-pass valve on rear pump look good. ????? ????
david val
01-14-2004 12:44:12
 Re: 830 3 cyl. hyd. noise in reply to fred, 01-14-2004 06:41:19
830's were made with open center gear pumps and closed center piston pumps, let un know your setup so we can think up an answer.
check if you don't create mechanical stress on the pump by transfering clutch pressure through crankshaft and pump drive into the pump. (check for visible front pulley endplay).
david
fred
01-14-2004 14:13:55
 Re: Re: 830 3 cyl. hyd. noise in reply to david val, 01-14-2004 12:44:12
dave tractor has gear pump, also only has 500 hrs.(like new) end play not there.any more ideas??? thanks
fred
01-14-2004 12:09:38
thanks Dale, but i already checked screen and put new filter in . On the rear pump there is a by- pass valve that lets front pump suck oil when rear pump not spinning. I checked valve and its ok. what throws me is sys. has good power with clutch out,seems like front pump ok. anyone help????? ????? ?
Dale in IN
01-14-2004 08:33:13
Fred. When you push the clutch all the way down you are shutting off the primary pump that feeds the hydrualic pump on the front of the engine. The squall you are hearing is the hyd pump starving for oil. I believe the primary pump is a small gear pump inside the transmisson case. Half way down on your clutch should allow you to stop your ground speed and all the way down stops every thing. That is a 2 stage clutch so you have live PTO.
The other thing could be a dirty hyd filter located on the bottom side of the transmission behind the left foot plate. There is also a screen that screws in from the right side. It looks like a 1 1/4 Pipe plug.
