Difference in Hydraulic Cylinders for A,M,R etc
Kevin
01-14-2004 06:35:53
I am looking to get a Hydraulic Cylinder for my
R and don't know how to tell which one would be
"correct". I have a parts book that lists the
individual parts, but not the whole thing.
Leon
01-15-2004 10:54:34
 Re: Difference in Hydraulic Cylinders for A,M,R et in reply to Kevin, 01-14-2004 06:35:53
Kevin--- I am so STUPID!!!!! You need to find a cylinder with (Trumpet FAn Fare) F827R cast on the side of the main casting. Geez, Leon, How can you be so DENSE!!!
Leon
01-14-2004 14:51:00
Kevin, what I did was to look up the part # of the actual cast casing of the remote cylinder in the R parts book, and since it was F827R, I then went to the G parts book (since G parts start with the letter F) and looked at the casing part # there. It is the same as the R one, F827R. I have a couple of these, but I'm not home to look up the casting # on them. If nobody replies before tomorrow with the cylinder number, I'll TRY to remember to post it. Between having Senior moments, CRS syndrome, or brain farts(your choice of expression), I sometimes completely forget stuff!! :-)
Kevin
01-14-2004 19:32:51
 Re: Re: Difference in Hydraulic Cylinders for A,M, in reply to Leon, 01-14-2004 14:51:00
There are a couple on EBay with casting #3162R?
What do they fit?
Leon
01-15-2004 05:49:04
 Re: Re: Re: Difference in Hydraulic Cylinders for in reply to Kevin, 01-14-2004 19:32:51
Kevin, they are A3162R cylinders. The A part tells you that it is for an A. If the number started with a B, it's for a B, and if it's an F, then it fits the G and apparently the R. That applies if it is this old style with the double manual stops like the ones on Ebay. If it is the next newer style, with the hydraulic stop, a number starting with B is for a 50, A is for a 60, and F is for a 70. Hope this clears up some confusion. Leon
