Antifreeze seeping into cylinder
Andy
07-03-2003 14:44:35
i have a 1948 b and well i went to start it the other day and well i opened the pet cocks and cranked it over and to my suprise antifreeze at least a 1/4 of a cup of antifreeze come out of pet cock does anyone no whats up with it thanks help.
Lee
07-03-2003 23:18:08
 Re: antifreeze seeping into cylinder in reply to Andy, 07-03-2003 14:44:35
Not to sound like I'm making fun of you but yeah, antifreeze is leaking into your cylinder. Could be a cracked head or block or just a leaking head gasket. If this is the only problem then I would suggest some Bar's leak as that is much cheaper than the overhaul to find/fix whatever the actual problems is. It isn't possible to determine exactly what the cause is without taking it apart. See my post about 'smoke' above, for me up to 4 cups at startup and all gone now. I know I'll be replacing the 'repaired' block that I had welded last summer someday so Bar's leak is just for a year or two.
